I am glad for all the work on TP3. One major flaw that I see is there is no simple way to change themes. I used help menu to go to the manual. IT tells me where the themes are located and how I can make changes to them. But, that is it. It doesn’t tell me how to select a different theme to use it, and I can’t figure it out! Then I read how to use a theme and it shows a basic theme - but it says nothing about how to install it. I used to do this in TP2 - long time ago. I can’t remember how to do this.
May I please suggest that it would be a good idea to have a theme selection popup list, either in the menu bar, or in the prefs window? As simple as TP3 is supposed to be, this really should not be such a headache trying to understand how themes are selected.
Thanks for listening
