I can’t seem to find the correct way to find a shortcut to these actions, any ideas/tips?
Both this
and this
as well as a few other variations aren’t working.
Appreciate any input!
Thanks,
Jacob
Both this
and this
Thanks,
Jacob
Hi Jacob,
If you want to rebind keys, I personally recommend Keyboard Maestro.
Or, you can do it in Apple System Preferences > Keyboard > Shortcuts:
I hope that helps!
Hi Jim,
Thanks for the reply!
I’ve got some shortcuts working right now for TaskPaper through the Mac System Preferences, the problem is that I can’t figure out the exact string I need to type there to correctly target the TaskPaper menu items “Format As Task”, “Format As Project”, and “Format As Note”.
For whatever reason the normal “Format As->Task” string doesn’t work.
Have you managed to bind a shortcut to those actions?
Thanks,
Jacob
Yep. I have them working in my screenshot above.
Just use the words (leave out Format As).
It worked! That’s cool, I guess I misunderstood how macOS handles keyboard shortcuts assignment.
Do you know why just using the words like that worked correctly?
Thanks so much
That is really a question for the macOS engineers.
My guess is that the System Preferences Keyboard Shortcuts do a search through the defined app’s menus/submenus, and the first match is targeted.
Interesting, you managed to solve my Taskpaper problem and teach me something new about macOS. Thanks!
Jacob
You’re welcome Jacob! It is a pleasure to help!
