Can themes be used to control printing format in TP3?
Can I set up themes that apply to TP documents when printed? I’d like to use one theme when editing and another when printing. Any way to do that?
You can in the TaskPaper 3.5, which is still in preview. You can select the stylesheet that you want to use through the printing panel.
Argh! I’m using 3.5. Didn’t notice the drop down in the print dialog. Thanks much.
