I made it a video to show that I’m not crazy. While deleting a tag with the delete key, the task outdents instead.
I have the same problem too.
and After V.162 Update
it became veeeeery slow and heavy. type response delay.
Opps and thanks, must be some edge case of delete (supposed to be from start) of item to outdent. Anyway I can reproduce it, a fix should come in next release.
Anyone else noticing this? Is it a particularly large document or just any document?
my taskpaper file :
7k (I think it’s not particularly large)
1,596W
there is no delay in Focus a project
Seems to be fixed in build 163.
thnx!
