Control+t (transpose-chars) is one of those Emacsisms that work almost everywhere in MacOS. Can it be made to work in Bike also?
Thanks for Bike! I just bought a license. (I thought I should, before requesting an improvement.)
FWIW an interim stop-gap:
(e.g. to assign to ^T – for Bike.app – in Keyboard Maestro)
BIKE – transpose 2 characters around cursor.kmmacros.zip (2.5 KB)
"use strict";
ObjC.import("AppKit");
// Transpose any two characters flanking the cursor,
// if the selection is not extended.
// Rob Trew @2022
// main :: IO ()
const main = () => {
bike = Application("Bike"),
doc = (
bike.activate(),
bike.documents.at(0)
return doc.exists() ? (
Boolean(doc.selectedText()) ? (
Left("Selection extended - do nothing.")
const se = Application("System Events");
$.NSPasteboard.generalPasteboard
.clearContents,
se.keyCode(124),
[1, 2].forEach(() => se.keyCode(
123, {
using: "shift down"
se.keystroke("c", {
using: "command down"
delay(0.2),
fmapLR(
s => 2 === s.length ? (
copyText(
[...s].reverse().map(
c => (
se.keystroke(c),
c
.join("")
se.keyCode(123),
s
clipTextLR()
) : Left("No documents open in Bike");
// clipTextLR :: () -> Either String String
const clipTextLR = () => {
// Either a message, (if no clip text is found),
// or the string contents of the clipboard.
v = ObjC.unwrap(
.stringForType($.NSPasteboardTypeString)
return Boolean(v) && 0 < v.length ? (
Right(v)
) : Left("No utf8-plain-text found in clipboard.");
const copyText = s => {
pb.clearContents,
pb.setStringForType(
$(s),
s
// Left :: a -> Either a b
const Left = x => ({
type: "Either",
Left: x
// Right :: b -> Either a b
const Right = x => ({
type: "Either",
Right: x
// fmapLR (<$>) :: (a -> b) -> Either a a -> Either a b
const fmapLR = f => lr =>
"Left" in lr ? (
lr
) : Right(f(lr.Right));
Just a note that I’ve added this to my list. Right now my focus is on adding rich text to Bike. After that I plan to work on text input system and expect to add support for transpose then.
This is implemented in Bike 1.7 Preview Bike 1.7 Preview (90) - #26 by jessegrosjean
