Boolean Suggestion
I was trying to use Boolean logic to search on two different tags at the same time. It didn’t work. I tried “@task AND @today”, either of which will bring up several entries. They do not seem to work together.
Suggestion: Would be nice if you could use Boolean search parameters in TaskPaper.
Thanks
David
try “@type=task and @today”
Sorry guys, I feel the complete idiot today, I was trying @task AND @today. I should have been trying @task OR @today.
Yes, Boolean works nicely in TaskPaper 3 (sheepish grin).
ADDED: I did discover that you do have to put the operator (and, or) in lower case letters of it will not work.
David
Moving on with Boolean, Here is a tip I just learned. If you want to exclude @done (archived) items from your search you have to make each search parameter be followed by the line “and not @done”.
This is correct: @task and not @done or @nearfuture and not @done
This is NOT correct: @task or @nearfuture and not @done
Past experience would suggest that I could have just excluded @done form the results in my (logical) summary. But here, you have to do it element by element. Still, other than saving search strings (will give that to Typinator if I start using this a lot), it’s a pretty cool idea and a hearty “well done” again to Jessie and TP3.
Here’s a different (maybe more flexible) way to exclude items in the archive:
@task or @nearfuture except /Archive//*
So create your normal search, and then tack except /Archive//* to the end of it. You can read more about except and other set operations here: http://guide.taskpaper.com/formatting_queries.html
Also note that you can use parentheses to group things. So if you really did want this logic:
You could do it shorter with:
(@task or @nearfuture) and not @done
Excellent. Thanks.
