Is there a way to do this in WriteRoom? The only indent I can seem to find only indents the first line of a paragraph. Is there a way to get even the line-wrap to indent?
Sorry there isn’t.
Update Actually you can if you create a document in rich text mode. That will allow you to set tab stops and tail indent. But I would recommend against that. WriteRoom 3 is really best as just a simple distraction free place to type… if you need the rich text editing aspect you’d probably be better of with an app that’s more dedicated to rich text support.
Makes sense. Thanks for the reply. In the meantime, I actually did resort to modifying the underlying rtf. I had never really thought about how .rtf worked before and was kind of delighted to find it so amendable!
