Bike Outliner adds inline navigation buttons so you can zoom through your outline with just your mouse. It also adds a navigation bar with back and forward history and breadcrumbs.
I think my focus next release will be to cleanup settings. My plan is to move all the Editor settings out of editor panel and into separate interface associated with a particular view. Goal is that you’ll be able to have per document editor settings. And also support for different settings when in fullscreen mode. Also sets UI up for eventually stylesheet rules (unlikely in next release).
yes - I like the focus mode, (although it made more sense to me in the video than the text)
highlighting the line being edited really helps
just renewed - very willingly
just found how the formatting works ( although I suspect it’s been around for a while) - I tend to prefer keystrokes over mouse actions - that’s a great combination of memory jogger / educator with the keystroke indicated underneath
and just to note I appreciate the Hookmark integration.
