Bike default window size change
Is there a way to change the default window size?
When I first launch or open an existing Bike document, the window size seems set to a default size. I would like to know if there is a way to change this, such as making it narrower.
Sorry there isn’t, but if you never close the document (Just quite the app) then when the document is restored it will be opened at the same size.
Is this a feature that’s coming soon? One of the most annoying things about Bike is that I can’t remember the new document window size and position.
FWIW I always open my Bike documents with a Keyboard Maestro macro which sets a custom window frame (size and position).
You could also close Bike with a macro which records the last frame for use at the next opening.
I didn’t realize this was really a bother! :slight_smile:
Try this preview, I think it does things better:
Thanks for 1.22.2. (196)
That seems to remember my chosen window size !
