Bike command line piped into jq – e.g. listing highlit terms
I have a couple of Bike outlines here in which I have been highlighting terms of interest, and now I want to list those terms.
We can start by filtering in the Bike app GUI (⇧⌘F) with an outline path:
//*/run::@mark/..
Also, the new bike command line (Bike > Install Command Line Tool ...) can harvest matching lines as text, markdown, json, bike, or opml
Lets start with text:
bike get outline --refs '//*/run::@mark/..' -o txt
If we only want the highlit words themselves, without the line containing them, then we can first switch to json (the default, so we don’t need the -o switch now)
and then pipe the result into a jq query (jqlang can be installed via brew)
which pulls out just the highlit strings themselves:
.root.children[].text[] | select(.attrs.mark).string
Putting it together for the command line, specifying -r for text output without double quotes:
bike get outline --refs '//*/run::@mark/..' | jq -r '.root.children[].text[] | select(.attrs.mark).string'
Neat, I just gave it a try and success!
You could re-wrap the stream as an Array,
and tag on a jq sort_by,
before making it a stream again with []
[.root.children[].text[] |
    select(.attrs.mark).string] |
    sort_by(ascii_downcase)[]
but just piping onwards to the shell’s | sort -f seems lighter :slight_smile:
A post was split to a new topic: List of All Links in Outline (via bike command line tool)
With jq’s recurse, we can get things even without a Bike outline path.
For the flat listing of all highlit strings, at any depth of the outline, this time skipping the outline path:
.root | recurse(.children[]?) |
    .text[]? | select(.attrs.mark) | .string
i.e. at the command line:
bike get outline | jq -r '.root | recurse(.children[]?) |
    .text[]? | select(.attrs.mark) | .string'
and applying the jaq implementation of jq (with its --from xml switch), directly to a .bike file:
jaq --from xml -r '
  select(type == "object" and .t == "mark") |
  [.c[]? | select(type == "string")] | join("")
' notes.bike
