OK – here are some random thoughts! ![]()
Also, so I don’t have to keep uploading a zip file here, the theme now has a Git repo.
In general, it was a bit difficult, as I don’t know Javascript, and kept thinking in CSS.
Claude helped me, as I gave it both the documentation on the web site and the .ts file, but it of course made a lot of mistakes as well. However, it did help me get things to try, which I could then tweak. Thanks to the automatic update of the Bike window, troubleshooting was OK.
One of the things it did, was to create a helper functino so I could use hex colours, and then add custom colours:
// Helper function to convert hex colors to Bike's Color format
function hexColor(hex, alpha = 1.0) {
// Remove # if present
hex = hex.replace(/^#/, "");
// Parse the hex values
let r = parseInt(hex.substring(0, 2), 16) / 255;
let g = parseInt(hex.substring(2, 4), 16) / 255;
let b = parseInt(hex.substring(4, 6), 16) / 255;
return new Color(r, g, b, alpha);
} function getCustomColors(isDarkMode) {
if (isDarkMode) {
return {
background: hexColor("#1a1e30"),
text: hexColor("#d7dbea"),
(Etc.)
} else {
return {
background: hexColor("#f8f9fb"),
text: hexColor("#3e4a77"),
(Etc.)
I do prefer HSL, though. ![]()
- I struggled quite a lot with selectors, as I didn’t know when to use
.selector.@selectoror justselector. Why is itparent() = true, but@type = heading? And I could probably doparent() = false, but what if I want to select things that arent’t headings? - As mentioned, just like with
theme.hideControlsWhenTyping, I’d like an option likehideHandleWhenNoChildren. - I had to switch the order of the bold and the italics rule to get bold+italic to work.
- I also don’t quite know what the things in parentheses mean, like
(env, row). - It would be nice with something like layers in CSS, to decide priority. For instance, I’ve struggled with selection not playing nice with the background I want for code. The fix was to change the code background to have alpha, but that lead to another problem: (I also have one more code problem.)
I want to have code runs to have a background, but just behind the text, while I want code blocks/rows to have the colour all the way to the right.
The former works perfectly – but when the background has alpha, I can see where the different row backgrounds overlap. They also don’t align on the right side, for some reason. (And, where is the spacing change when something gets indented set? I would need to know that to be able to adapt the background offsets and heights to make it perfect.)
One of the things I did, was to colour the arrow.down.forward, in the header colour, when it’s in the header. What would’ve been logical for me, was to create an if statement inside the RowRule where that is set. But to get it to work, I instead made a separate rule like defineRowRule(".@type = heading and parent() = true and focused-root() = true", (env, row) => {}.
So, I had these two rules:
defineRowRule(".parent() = true and focused-root() = true", (env, row) => {}
and
So when I wanted to also colour the handle for collapsed headings, I tried to think similarly, and create the second rule here, expanded from the first:
defineRowRule(".parent() = true and collapsed() = true", (env, row) => {}
defineRowRule(".@type = heading and .parent() = true and collapsed() = true", (env, row) => {}
That didn’t work, and I had to do this:
defineRowRule(".@type = heading and collapsed() = true", (env, row) => {}
However, this also selects when the heading is empty, even though it’s not a parent and not collapsed. ![]()
Still – I’m quite pleased with how it looks! And it’s so fun to see my own ideas merge with the Grosjean Polish™️. (Even though there’s still quite a lot of jank, as you know well.)
Here’s my theme, vs. the default. My goals:
- I’ve tried to give it a softer look (while hopefully still be readable).
- I also wanted to fix some of the annoyances I have with Bike 1.x:
- Headings don’t stand out, as they look just like bold text.
- I didn’t love that text in lists on Indent Level 1 was exactly the same as regular text on Indent Level 2.
- I don’t think code stands out enough. (Bike is lovely at displaying and writing code. I’d totally use it as my code editor if I could.
) - I also think notes should stand out more (by standing out less
Lots of these could be achieved without changing the look quite as much, though! So I’m planning on making a greyscale version as well.
Oh, and I’ve also noticed that Bike struggles a bit with the text replacement from Raycast. Among other things, I use it for emoji – and Bike will create a new line, while other apps doesn’t. I think Raycast uses the clipboard somehow for the text replacement. ![]()
Edit: Smart to move this over to a new thread! ![]()
