This would be quite useful, actually. I hope this is still planned sometime in the near future:
This seems to cause Bike 274 to hang consistently:
- Filter outline by whatever (match not needed)
- With filter still active, close document.
If document was unsaved, a save dialog pops up. If you click Delete or Save, Bike hangs. If this was an existing document, Bike will hang on Close.
Tho I do wonder if “selection”, as in the extension-kit’s
/** Select rows to create a "block" selection. */
selectRows(anchor: Row, head?: Row): void
is quite the right metaphor, here ?
A set of (probably discontinuous) matches is perhaps a slightly different animal from a selection block defined by putting down an anchor and extending a range by some number of rows.
query.value.forEach
does seem a closer fit …
continuing to test this. there’s a long delay before being able to add link to row. i guess Bike is reading all the rows, and I have a lot of rows.
Also, the link arrow doesn’t let me jump anywhere (either link to row or URL link)
Not being able to click the link arrow may relate to something which, I understand, is fixed for the next build (z-Axis layering of the link decoration),
but you may find, meanwhille, that selecting any blue text in the link range,
and using ⇧⌘O, does work. (Bike > Go > Open Link)
works. thanks
if i doubleclick on elit and drag directly downwards, i only select the words elit and the words after
however, if i inadvertently drag left over one or more preceding words (here, adipiscing) after doubleclicking on elit, i end up selecting the preceding words too, which i don’t think is your intention.
Can you explain in a bit more detail? Is this on by default in VS Code? I’m not sure that I see it. Also, I think this information is already present in Bike’s breadcrumb UI?
Thanks for pointing out this performance regression. Should be fixed in release later today.
I have added documentation to Calendar’s readme here:
Feedback welcome… do those docs help you? (For generating a years worth of dates use the command “Calendar: Year”.
That’s correct, Select All isn’t really compatible with filter views.
I don’t think I want to modify selection to be discontiguous. It would add complexity and also require extension API changes. Could you describe a few scenarios where you would want to use this?
One possibility:
Currently when you have a filter, and then long click on the filter (three horizontal line) leading icon you get a popup menu that allows you to “Copy Matches without Children” in addition to other actions. One option would be a new menu item along the lines of “Apply Command To Matches”, which would then open command pallet and apply selected command to only matches. Maybe useful for your cases?
I completely missed this feature! I think it does 90% of what I need it to. I’m still unsure how to avoid duplicates if I want to include both matches + parents/ancestors AND preserve outline structure, but that’s probably a skill issue.
As for bulk operations on matches → yes, I think applying a command through command palette would be a nice solution.
ah, it’s one of those command panel things. thanks.
feature request for calendar (for well after v2 is published): to display the day of the week alongside the date
This might already be possible… do you mean in the outline row? If you go to Bike > Settings > Extensions > Calendar then you can fill in the patterns that are used when generating Year, Month, and Day rows.
that, plus letting Claude look at core-extensions/src/calendar.bkext at main · bike-outliner/core-extensions · GitHub
gave me this to paste in:
{“weekday”:“short”,“day”:“numeric”,“month”:“long”,“year”:“numeric”}
and it works!
Sorry, I mean the window title. I use folder templates, so I have the same filenames in different directories. Being able to show the parent folder on the window title would help tell one from another.
Looking into this.
When I turn on Keyboard Navigation I see the change in behavior that you describe. Tab/Shift tab moves by day, and I think this is expected. When turning on keyboard navigation all tabbing becomes very granular. I also see an indicator in light/dark mode. I’m not sure why you are not seeing that… actually I see it sometimes, not other times…
Will look into that.
In any case I will also add navigation commands to the go menu for Sidebar (Command-1), Editor (Command-2), Inspector (Command-3). That will at least allow you to quickly switch to a known location without first having to consider your current location. Or as a quick way to get back to editor from calendar when Keyboard Navigation is on.
I think that starts to get too complicated, especially since I think this information is already available in breadcrumb bar. The complication is exemplified by all the options that VS code provides, everyone will want something different! ![]()
What I think I can do is provide an API so that you could set window’s subtitle yourself from an extension. Does that seem useful for your case?
breadcrumb
Could you help with a screenshot of the breadcrumb bar showing parent folder of the active file? I couldn’t find it and google didn’t help. The Interface Manager mentions Title Bar. And yes, I’d be grateful for such API.
