Bike 2.0 (Preview 266)
If you really thing this is happening please pay special attention to the exact behavior. I haven’t notice this happening to me.
Please make sure to check Setting > General > Prompt to send crash reports
With that checked it should be that:
  1. After a crash
  2. Next time you launch, Bike will start an email for you with crash report
  3. You just need to send that email please.
Generally it’s been very stable for me lately, and I haven’t been getting many crash reports. So it would be good to find the problem you ran into.
Does a theme file make it possible to adjust space after/before a heading or any other element?
No, not currently. This is another one of those things that wouldn’t be too hard to add, but it starts to get a little unclear to me how much config I should pull out of the styling code and put in the theme.
@jessegrosjean Just sent the crash report via email. Let me know if you need anything else. Also, right now when I press esc to escape block mode, for some reason it still selects all the text in the current line (please see gif below). In Bike 1 it would go back to the blinking caret, which I think is a better UX because it more clearly signifies that I’m in text mode. Also, there’s an extra keystroke because when I press the up arrow, it shows the caret, but it doesn’t actually move the caret up one line.
Is this intentional? BTW, I appreciate the work on the custom keybinding configurator in Settings, that’s been a big boon for me!
CleanShot 2026-03-22 at 18.44.59
Thanks. Did you use different email than this account? Anyway, I’m just about to release next version, please try and submit any crashes again for the new version.
Noted and I think I agree… though this will get even worse in next release, but I expect to fix after that :slight_smile:
occasionally, the arrows stop being clickable for folding. i can still use the menu command to fold and unfold. restarting restores the behaviour. it might have something to do with being in full-screen tile mode (since that’s often how i have Bike). I can’t reliably reproduce it. it just happens.
I decided to just try parsing this outside of what the normal parser does. Give it a try and let me know error cases you find.
I thin this is fixed in latest release. I also changed behavior to better match markdown. Now you can only have empty rows between ordered siblings (and have the order continue to increase). If you add a non-empty row the order will restart at 1.
Lastest 268 release should include Expand All, Collapse All, plus “By Level” variations.
I think this is working correctly now. I “think”, let me know if you still run into problems.
Yes, I had submitted the crash report using a different email (it would’ve been a gmail account).
