New Bike 2.0 Preview today!
- Added sidebar live queries
- Fixed layout bugs (more remain)
- Fixed some memory leaks
Sidebar queries are configured by the extension API. If you have run a previous version of Bike 2 a @Startup extension is installed that doesn’t use that API, so you won’t see live query. If that’s the case you can delete that @Startup extension, and then restart Bike. A new @Startup extension will be created that uses the new API. To do this:
- Open Bike > Extensions… menu item.
- In the Finder window that opens, delete the @Startup extension.
- Restart Bike.
Now when you create a heading in your outline it should show in the sidebar under “Headings”, you might have to expand “headings” to see it. You can modify your @Startup extension to create your own live queries.
What’s next? The goal this week was to revisit and polish the update cycle and animations. I got a good start in that direction, didn’t finish. So that’s the goal again this week.
