I downloaded bike 2.0 to have a look as the side bar interested me. But it says i have to renew my license but its active for one year? Maybe it has expired, im not sure.
It also says you can only have 3 active uses.. but i only have 1 laptop on which i use it so not sure why its saying 3 active uses. Can someone clarify how to release 2 uses that im unaware of?
You can still use Bike after one year with all features unlocked. However, if you want to get new updates, you’ll need to renew your license.
As for three active licenses, you might have some misunderstandings. “You are allowed to have three active licenses.” means you can use Bike on three diffrent computers with one license. It doesn’t mean that your license is connected to other users or computers.
If you email me (jesse@hogbaysoftware.com) your email or license key I can reset those other activations. Also if you have access to the computer’s where it was activated you can deactivate from there… though easy enough for me to do it.
Also, here I’ve explained best that I can how licenses work:
