- Added software update
- Polished selection model
- Started outline search/filtering. Work in progress
- More app infastructure, including settings. Much of it is not connected
I’ve messed probably too much with the selection model, but I think it’s quite good now. I think pretty much every selection movement is now reversible if you make the opposite movement. Not even NSTextView does that all the time, so ![]()
selection model
It’s working very smoothly.
Lowest friction I’ve seen in an outlining model.
( I take my hat off to all that design and implementation work – thank you ! )
