- Added Row > New Indented Row (Command-Shift-Return)
- Added Preference for default document type and extension
- Added Exit outline mode using Option-Right/Left
- Added Scripting access to row attributes
- Typing animations finish faster when typing fast
- Improve text caret animations when undo/redo
- Respect NSScrollAnimationEnabled user defaults setting
- Ignore first click (maintaining selection) when activating window
- Fixed Extend selection by word/line when dragging mouse
- Fixed
---read from plain text is treated normally - Fixed Option-Up-Shift to properly extend selection
- Fixed Don’t allow collapsing leaf rows
Added Scripting access to row attributes… I don’t know how immediately useful this will be, these attributes will not be visible in Bike UI. This will allow you to read/write custom attributes, and these attributes will be saved in .bike and .opml formats.
tell selection row
exists (attribute named "test") -- false
make attribute with properties {name:"test", value:"value"}
value of attribute named "test" -- value
set value of attribute named "test" to "new value"
value of attribute named "test" -- new value
delete attribute named "test"
end tell
end tell
