Bike 1.22 (190-193) Preview
  • Fixed changed open behavior
Previously in 190-192:
  • Default to no xmlns in Bike documents, but preserve when found
  • Fixed crash case, show alert instead
  • Changed how file attributes are written
  • Removed auto-naming feature for new documents
  • Fixed problems when importing HTML/RTF lists
  • Changed open behavior to create untitled document instead of open panel
Trying to fix two issues that I haven’t been able to reproduce myself. If you see a crash please let me know!
To get preview releases through Bike’s software update select: Bike > Preferences > General > Include “preview” releases. Or download directly from Bike’s releases page:
A quick FYI and an inquiry to see if others have noticed that with the (190) preview, Bike Shortcuts have disappeared from the Apple menu and Bike shortcuts that were working with previous previews (<189) no longer work. [error msg: A shortcut cannot run because an action cannot be found].
I’m not a big shortcuts user other than the Today shortcut that I use to start each day so this isn’t such an issue for my workflow. It’s easy enough to just type in the date :grinning:
That’s no good. Anyone else seeing this? My computer is not a great test cases because I have so many different build of Bike lying around. I still see Bike shortcuts, and when I launch Bike 190 and run a shortcut, it works to automate Bike 190.
I was able to troubleshoot and solve the problem on my own (amazing statement from someone with zero coding skills, though a rough understanding of how things work under the hood :crazy_face:).
Yesterday, I had downloaded Bike 2 to see what folks were talking about and quickly found it overwhelming and just left it sitting in my applications folder. I moved it to the trash a few minutes ago and voilà, Shortcuts are working again.
Lesson learned: don’t keep a beta version of Bike on your device.
Nice work… and sorry I didn’t think of that. Right now Bike 2 preview doesn’t have any AppleScript or Shortcuts support, so if it’s the one that Shortcuts looks at then there will be no shortcuts.
Perhaps one should install the experimental builds in the user/Applications folder of a guest/test account, rather than in the system Applications folder ?
That seems reasonable, though I have no idea if that will fix issue in all cases. How shortcuts/AppleScript actually choose which binary to launch, I don’t know.
So far so good – I can continue to use my Bike 1 scripts in my main account,
and also experiment with Bike 2 builds in a testing account.
(with Bike 2 at ~/Applications/Bike.app in the testing account, and Bike 1 at the system-wide /Applications.Bike.app)
I’ve just posted a minor (we’ll see right!?) change that defaults to not including a xmlns for Bike formatted documents. On the other hand it should preserve “one” if found.
Many thanks – that was fast !
And XQuery over XInclude is now working perfectly for newly-added .bike files.
(For files which had aquired the shadowing xmlns since late 2023, sed -i seems, I think, to be able to clean up by editing ‘in place’, without losing the extended attributes on which bike:// row links depend)
(If anyone wants to try the find and sed incantation I am using, they are welcome to DM me for it)
I downloaded the beta of bike 2 and also had problems running the Today shortcut so I deleted it and it started working again for me. I don’t want to go to the hassle of setting up a new account so I will wait until they can happily coexist - or Bike 2 is released.
Was there a recent change in the way Bike behaves when you close all windows and restart the app?
I was used to Bike always opening a new document when I opened the app (unless there were windows already open before I quit). Now if I close all docs before quitting, I get a prompt to open an existing document (similar to TaskPaper) when I next reopen the app.
But maybe I’m just imagining things at this point and I never bothered to close the Untitled window before quitting in the past :sweat_smile:
The behavior that I see is:
  1. If I leave a document window open when quitting Bike (ie I don’t close the window first) then when I launch Bike again that document window is restored and I don’t see an Open Panel.
  2. On the other hand if there are not any windows open when I quite Bike then I do see the open panel that you describe. I don’t particularly like it, and would rather have a new empty document :confused:
I think this behavior changed about a year back when I opted into a Bike specific iCloud folder. Generally I’m letting macOS frameworks decide what happens when launching Bike… they do it the first way when no Bike specific iCloud Folder, they do this “new” way when there is a Bike specific iCloud Folder. Doesn’t make much sense to me, but that’s the default OS behavior.
I do think I looked into “fixing” this a while back and didn’t find an easy route, but maybe I’ll try again.
Yeah, that’s the behavior I see too. +1 to prefer having a fresh new window on app launch if no other windows are open. You push a button and you write.
I’ve just posted a new preview (192) that I think fixes this.
Hmm, doesn’t seem to work for me. I still get an Open document pane if I quit Bike with no docs open beforehand. This stays true even if I check ‘close windows on quit’ option in Bike’s settings.
EDIT: What’s funny is that, with that Open document pane open, I can focus away from Bike, and when Bike regains focus, it will open a new document.
Ugh, and yeah I’m seeing the same thing now. Weirder is that when run from Xcode Bike behaves as I had intended, only ever opening the new document. I guess that’s why I though I had managed the behavior change, because it works as I had intended, but only when run from Xcode.
I thin this is fixed now… at least seems to work correctly for me both when run from Xcode and also when run outside of Xcode
Yep, seems like it works now! Will report back if I find any oddities. Thanks!
