Bike 1.21 (189)
  • Show alert when software update will require license renewal
  • Fix caret movement’s interaction with caret affinity
To get preview releases through Bike’s software update select: Bike > Preferences > General > Include “preview” releases. Or download directly from Bike’s releases page:
You won’t get this warning if this update happens to be the one that needs a license renew for you, but you should see the warning in the “next” update. The code to check is finally in there in this release.
I’ve just posted Bike 189 … should be exactly the same as 188, except it should fix a code signing issue that I hadn’t noticed in 188.
