Fixed text encoding problems when pasting HTML fragments
Previously:
Added Markdown to Edit Rows action
Changed Create row action Plain parameter to Text
Fixed Open Outline action to make outline frontmost
Fixed “License Required” spelling
Fixed iCloud folder icon, I think
Fixed case where text caret would stop showing in editor
To get preview releases through Bike’s software update select: Bike > Preferences > General > Include “preview” releases. Or download directly from Bike’s releases page:
Please pay attention to any issues around iCloud Drive folder. I had the previous version setup half way for one iCloud location ID, and half up for another ID. In terminal it should be that your iCloud documents get stored into:
Yes, iCloud vs Bike little bit strange.
3 different showing up in Terminal, Finder and ForkLift.
Especially by Hungarian localization: I have two folder with exactly same name…
Can you send screenshot? It should be you can move documents from old ones into the new standard one. Then delete old ones and they shouldn’t come back. I think. The standard one should have Bike’s icon overlaid.
