- Added Item > Group menu item
- Added Item > Duplicate menu item
- Changed to focus on item when bike link is activated
- Changed move to end of paragraph to move to end of current line, not start of next line
- Changed move by char cursor animation to flash (instead of slide) when changing lines
- Changed insert line cursor animation to flash (instead of slide) when starting from char == 0
If all goes well this should be the first update that you can do automatically with Sparkle. Bike > Check for Update… should do the trick I think.
