- Added appearance preferences
- Added foreground / background color preferences
- Added “Reset Typography” button
- Removed handle style preferences, just using standard
- Changed Find / Check panels to work better with custom background colors
- Changed outline mode selection blocks to use standard selection color
- Changed IME to use underline and selection color instead of yellow background
- Fixed row spacing to default to zero (also changed range to 0…1)
- Fixed problems with cached colors when switching light / dark mode
- Fixed problems of white text on bright yellow background when in dark mode
- Fixed number of visual glitches when switching between light and dark mode
- Fixed user defaults to store typed values instead of always encoding everything as data
I’m headed out for day, will respond to any questions when I get back or early tomorrow. I feel like I’m getting close to 1.0 feature set. I still need to do licensing, docs, lots of stuff … but I think app is getting close. With that in mind please keep an eye out for details that should be fixed before 1.0! Thanks!
