Added replace options to (Command-F) Find panel
Moved Find options out of menu and into always visible buttons
Delay item handle drag and drop start until drag has moved 8px
Press escape key in editor will first close any panels. Then it will toggle between text and outline mode.
Fixed Copy/Paste to have better indentation and whitespace handling when pasting from Bike into another app.
Removed “internal” bike: links. That is Bike links that don’t include the outline id. I think the length saving wasn’t worth the fact that they break when moved into another outline.
Added in progress Checking Panel. Use (Command
-;) to show panel and check forward. Use (Command-:) to show panel and check backward. Panel itself is a work in progress, but will at least give idea that I’m planning to support multiple bottom panel types.
I’ll keep creating a post for each release. But I’ve removed the forum “Bike Change Log”. Generally latest release notes and Download link should be showing up automatically when you launch Bike.
