Weird. It does work well with al the tests I tried. Are you running version 168? Maybe you are trying to archive the parent’s note instead of the task’s one. Let me explain
Project
Note
Task
In this case, the note is not the task’s note but the project’s. If you want to save add a task’s note, just add the note underneath the task.
