I just updated to the latest beta of taskpaper and my @today tasks are now appearing orange. I know this behavior can be modified in the user.less file, but when the task are given an @done tag is there a way to no longer have them appear orange. Trying to find a way to not have my archive filled with completed tasks that are orange.
Sorry for being late on this. Started a long reply, but got confused in the answer and so gave up.
In that first release the orange was in there as a demo and I added the rule for that at the end of the file, made it a little messy explain how to do what you wanted. Instead try this:
- Download latest TaskPaper 3 preview.
- Delete your existing
user.less file.
- Start or restart TaskPaper 3 preview to create a new “fresh”
user.less.
In this latest version I took out that “orange” rule. I think to get the behavior that you want you can edit the data-done rule to look like this:
item[data-today] {
color: orange;
item[data-done] {
color: @text-color;
> run[display] {
text-strikethrough-color: @text-color;
That is insert a new item[data-today] rule before it to set text orange when @today is present. And then update the existing item[data-done] rule to reset the color to @text-color.
