Archive done and @cancelled
Is there a way to expand the Archive Done command to also archive tasks tagged @cancelled? Or is there a script that performs the same archive function that I could modify to achieve this?
Searching around for previous answer I found this post:
I just added the translated script and wrapped it so that it can be run from script editor.
Awesome! Thank you.
So perhaps the updated path might be something like:
outline.evaluateItemPath(
    "//(@done or @cancelled) except " +
    "//@text = Archive://(@done or @cancelled)"
JS source of test
    'use strict';
        const main = () => {
            const outline = editor.outline;
            let selection = editor.selection;
                startItem = selection.startItem,
                endItem = selection.endItem,
                [removeExtraTags, addProjectTag] = [
                    'BRemoveExtraTagsWhenArchivingDone',
                    'BIncludeProjectWhenArchivingDone'
                ].map(k => Birch.preferences.get(k));
                // isOrContains :: Item -> Item -> Bool
                const isOrContains = a =>
                    b => a === b || a.contains(b)
                    archive = projectFoundOrCreated(outline)('Archive'),
                    doneItems = Item.getCommonAncestors(
                doneItems.forEach(each => {
                    // ---- PREFS :: EXTRA TAGS REMOVED ----
                    if (removeExtraTags) {
                        each.attributeNames.forEach(
                            eachName => eachName.startsWith('data-') && (
                                !['-type', '-done']
                                .some(k => eachName.endsWith(k))
                            ) && each.removeAttribute(eachName)
                    // ---- PREFS :: PROJECT TAGS ADDED ----
                    if (addProjectTag) {
                            projects = outline.evaluateItemPath(
                                'ancestor::@type=project', each
                            .map(x => x.bodyContentString)
                            .join(' / ');
                        if (0 < projects.length) {
                            each.setAttribute('data-project', projects);
                    // --------- SELECTION UPDATED ---------
                    if ([startItem, endItem].some(isOrContains(each))) {
                            previousItem = editor.getPreviousDisplayedItem(
                                startItem
                        selection = previousItem ? {
                            startItem: previousItem,
                            startOffset: -1
                            start: 0
                return archive.insertChildrenBefore(
                    doneItems, archive.firstChild
            return editor.moveSelectionToItems(selection);
        // projectFoundOrCreated :: TP3Outline -> String -> Bool -> TP3Item
        const projectFoundOrCreated = outline =>
            name => {
                const ps = outline.evaluateItemPath(`//@text = ${name}:`);
                return 0 < ps.length ? (
                    ps[0]
                    x => (outline.root.appendChildren(x), x)
                )(outline.createItem(name + ':'));
    const TaskPaper = Application('TaskPaper')
    return TaskPaper.documents[0].evaluate({
