Long time user, but actually pretty basic user. I have a set of Searches for my use, but I also have a very long, multilayer TP document. One document for all.
So my saved searches are way at the bottom. I would like a toolbar to show 4-5 of my common searches but I don’t think we have that. So for me, I scroll a lot or collapse my outline.
Kind of the same thing with Tags. I’d like a separate tag column (at least when i am on a big monitor).
You might have better luck if you navigate using the Palette menu options? They present the same lists as shown in the sidebar, but filter those lists as you type. Generally they are a faster way to navigate I think.
