One thing related to the tag input… If you add a tag and want to go back with CMD+Z, it removes one character at a time from the tag at the same time as trying to rewrite the tag or another one. So, instead of removing everything like a normal word, it takes many CMD+Z keystroke.
Maybe a simple fix could be to only expand the tag if the user press the down arrow to select the first tag in the popup so TaskPaper doesn’t always try to add one (I mean, the first tag in the popup is not selected by default, so not expanded, but if the user press the down-arrow to select it, now it will be expanded) ?
Thanks for fixing this, Jesse. I often have words that I want to turn into a tag by prepending @, so it was getting on my nerves. I never got around to requesting a fix so thanks to you too, CME.
