The script below appends a tag in the form @project(project / sub-project / sub-sub-project) to each selected item, or does nothing if the item isn’t under any project.
The script is an extract of the JavaScript for TP3’s native Add @project tag when archiving @done tasks behaviour, which Jesse kindly posted here. I don’t know any JS and as Jesse notes, the code was translated automatically from CoffeeScript, so the syntax might be a bit inelegant.
Intended use case:
Current workflow: Each morning, triage tasks by assigning @today (or @today(am/pm)) to those I want to do that day.
Problem: The @today view presents a hierarchical outline of the day’s tasks, with project headings. This is great for maintaining context, but the list is difficult to skim, and re-ordering tasks moves them out of their projects. I think I’d prefer a flat list of the day’s tasks which I can re-order freely, but would like to retain their project metadata for archiving.
Proposed workflow: Triage tasks by moving them to a project (such as 2021-01-26: @today perhaps) rather than tagging, but use a macro to execute the script below first.
// From TaskPaper's native "Add @project tag when archiving @done tasks" behaviour:
// https://support.hogbaysoftware.com/t/how-to-build-the-add-project-tag-from-preferences/3225/3
let outline = editor.outline
selection.selectedItems.forEach((item) => {
if (projects = ((function() {
var i, l, ancestors, result;
ancestors = outline.evaluateItemPath('ancestor::@type=project', item);
result = [];
for (i = 0, l = ancestors.length; i < l; i++) {
eachProject = ancestors[i];
result.push(eachProject.bodyContentString);
return result;
})()).join(' / '))
item.setAttribute('data-project', projects);
editor.moveSelectionToItems(selection)
