I would love if there was a hotkey added to copy to clipboard the current active line in TaskPaper.
Right now I am forced to emulate three keystrokes to do that:
And I really dislike that.
Thank you.
Thank you.
For something like an Execute JavaScript action in Keyboard Maestro, you could use a script along these lines:
( In the withOptions object, change the textProperty value from bodyString
to bodyContentString
if you donβt want to copy the Taskpaper bullet-hyphens, colons and tags )
'use strict';
const main = () => {
const main = () =>
unlines(
concatMap(
x => {
const txt = x[options.textProperty];
return options.skipBlankLines && 0 ===
txt.length ? (
) : [txt];
editor.selection.selectedItems
// GENERIC FUNCTIONS FOR TP3 CONTEXT ----------
// concatMap :: (a -> [b]) -> [a] -> [b]
const concatMap = (f, xs) =>
xs.reduce((a, x) => a.concat(f(x)), []);
// unlines :: [String] -> String
const unlines = xs => xs.join('\n');
// TP3 MAIN ---
ds = Application('TaskPaper')
.documents,
lrResult = bindLR(
ds.length > 0 ? (
Right(ds.at(0))
) : Left('No TaskPaper documents open'),
d => Right(d.evaluate({
withOptions: {
skipBlankLines: true,
textProperty: 'bodyString' // or 'bodyContentString'
return lrResult.Left || (
lrResult.Right
// GENERIC FUNCTIONS FOR JXA CONTEXT ------------------
// Left :: a -> Either a b
const Left = x => ({
type: 'Either',
Left: x
// Right :: b -> Either a b
const Right = x => ({
type: 'Either',
Right: x
const bindLR = (m, mf) =>
undefined !== m.Left ? (
m
) : mf(m.Right);
// MAIN ----
See:
βS (Control-S) with βC should do what you want in two keystrokes.
Of course, Keyboard Maestro can make this into one keystroke.
Works perfectly. Thank you.
