Is it currently possible to manipulate attributes with AppleScript? I want to grab a URL and title from a Safari tab and create a row in a Bike document that has the URL applied as a rich text link.
I personally use this:
Copy as Markdown Link - Macro Library - Keyboard Maestro Discourse
(or Code > Download zip
here: RobTrew/copy-as-md-link: macOS Keyboard Maestro macro group – single keystroke to copy MD links from different applications.)
to paste a (label, url) pair as a blue link in Bike.
(The macro creates plain text, RTF, and formatted Bike clipboard content)
More generally, the AppleScript route is by reading and writing the
htmlContent of row
property, which returns and expects text with HTML formatting tags.
Selecting the blue line below:
( url with label copied from Safari and pasted into Bike by that Keyboard Maestro macro)
and evaluating the AppleScript snippet
tell application "Bike"
tell selection row of front document
html content
end tell
end tell
yields:
<p>
<a href=\"https://support.hogbaysoftware.com/t/accessing-rich-text-attributes-with-applescript/5021\">Accessing rich text attributes with AppleScript - Bike - Hog Bay Software Support</a>
</p>
To create formatted content through AppleScript, you prepare the HTML for a row (between <p> .... </p>
start and end), and then assign the the value of the html string to the htmlContent
property of the row.
PS if you want to place formatted Bike content in the clipboard, you will need to use the AppleScript interface to ObjC classes – particularly this one:
NSPasteboard | Apple Developer Documentation
(I find it easier to do all this in the JavaScript flavour of osascript
, and you will see JS versions of how to do this in the KM Macro above)
e.g.
// Requires a preliminary incantation:
// `ObjC.import("AppKit")`
txt => {
pb.clearContents,
pb.setStringForType(
$(txt),
utiOrBundleID
txt
( The Bike clipboard type identifier is com.hogbaysoftware.bike.xml
, and, of course, the string submitted has to constitute well-formed Bike XML)
