Ability to fully expand node in Index
I wish I could right-click any node here and basically “Expand recursively”.
I’m using bike more and more as an “everything” app. It’s completely replaced Obsidian for me (and will replace Notes once there’s an iOS version!).
One thing I frequently do is have my coding agents leave summaries/notes/investigations here via the bike CLI tool. I love it!
Ah, this is in the sidebar, that confused me at first. I think it should be that Option-Click on the triangle will do what you want?
Ah, glad you are funding CLI useful
Yep, opt+click was the trick. I was looking for a context menu item. Thanks!
