Absolutely love Bike Outliner. One thing I prefer about OmniOutliner still is that command A selects the row, not the whole document. Could this be a setting, better yet, could we choose key bindings for both types of select All?
There is Edit > Selection > Select Paragraph (Command-Shift-L). Also, depending on your needs, there is “outline mode” where selection is always full row. Use Escape to toggle in/out of outline mode.
I routinely strike the escape key to select a row.
One solution I have seen in other apps is to have command-A select the row, and then press it again to select everything
Oof, that would drive me crazy. As a longtime Mac user, ⌘A means “select all” unambiguously, and that meaning shouldn’t change on repeat. Since a Bike doc essentially feels like (is?) a text document, the current behavior of literally selecting all seems exactly right to me.
(Keyboard Maestro makes it a snap to change your keybindings!)
I think generally Bike’s default behavior will stay as it is now.
