First up, I really like minimalist software curiously capable of more than it appears. Taskpaper fits that category. Thank you!
There are situations where searches don’t work with 100% accuracy. Here’s how to replicate that.
Create some tasks and tag with with @ peskyusers. Note that I’m putting a space between @ and peskyusers to avoid creating forum tags.
Start an editor search for not @ peskyusers - all is well (probably).
Now add a blank line under one of those peskusers lines. Put a tab on it, and nothing else, or anything other than than a task. Refresh the search, and the peskyusers task will remain in a not @ peskyusers search.
This may be linked to the logic for tasks and subtasks that don’t all fit a search.
Searching for a tag shows the non-qualifying branches collapsed. Searching for not-tag will include a tagged parent if it has non-tagged subtasks.
Nice! Thank you for the time you took. Learning Javascript is a priority right now. I have uses for it in Taskpaper and I also want to be able to get more out of Tap Forms, another Javascript-enabled application.
Your example is yet more learning material for me as well as an answer to my quibble.
Another complication in determining if something is a descendent or sibling of an item is blank lines embedded to break a comment into paragraphs. The blank lines in that case should be considered part of a single comment.
Not sure what that is exactly in your usage – TaskPaper is an outliner, and the central model is a set of relationships between \n delimited lines.
Part of its beauty, and the enormously varied range of ways in which it used, is that the model is kept very clean and very simple. There is only one way to group lines (or nodes or items to use the terminology of the API) – you make them children of a common parent.
(that may suggest a way of representing the comment entity in your particular workflow – a comment child line, with a set of its own children).
Experimenting with the Scripting API is a good way to build intuition about the architecture and how to work with it.
