As a generalization of @complexpoint’s fine script for Sorting top level projects alphabetically, which comes bundled with a generous master class on scripting, here is a script which sorts any arbitrary hierarchical level of the outline (by which I mean the currently selected node and its siblings).
// Sort currently selected node and its siblings.
(function() {
var selection = editor.selection.startItem, // The selected node (or the starting item of a selected range).
selection_parent = selection.parent; // The parent of the selected node.
editor.outline.groupUndoAndChanges(
function() {
var sorted_siblings = editor
.outline
.evaluateItemPath('following-sibling::* union (descendant-or-self::* intersect ancestor-or-self::*) union preceding-sibling::*', selection) // Obtain the item path across all siblings of the selected node...
.sort(function (a, b) { // ... and sort them. (Sort callback reused from a script by @complexpoint.)
var strA = a.bodyString.toLowerCase(),
strB = b.bodyString.toLowerCase();
return (strA !== strB) ? (strA < strB ? -1 : 1) : 0;
sorted_siblings.forEach( // Uproot the unsorted nodes from their common parent...
function(x) {x.removeFromParent()}
selection_parent.appendChildren(sorted_siblings); //... and graft them back in the right order.
tp3 = Application('TaskPaper');
ds = tp3.documents;
}) : undefined;
This is my first TaskPaper script (or JXA script for that matter); feedback on style or content warmly welcome.
Thank you very much for all your contributions. This tool is awesome, and even more with your posts and help.
