First, How do I make a TaskPaper stylesheet!
Once you have a custom theme here are some example rules for styling tags:
Change default tag color:
run[tag] {
color: green;
Change default color of only the tag name or tag value part of a tag:
run[tagname] {
color: blue;
run[tagvalue] {
color: red;
Change color of specific tag. In this case the @priority tag is colored red:
run[tag="data-priority"] {
color: red;
Change color of specific tag and tag value combination. In this case @priority(2) is colored orange.
item[data-priority="2"] {
color: orange;
Is it possible to target tags with relative values? Like <=[d] today?
Sorry no, but I agree it would be a good feature.
Given the task:
- Task @repeat(7) @due(2021-01-29)
Is it possible to style the due date (tag value) exclusively?
This styles the tag values of both @due and @repeat:
item[data-due] {
> run[tagvalue] {
color: red;
I think this is what you want:
run[tag="data-due"] {
color: red;
Thank you, and sorry if I’m missing something—but doesn’t this style the whole tag (@due(2021-01-30) rather than only 2021-01-30? I’d like to style just the date, for better legibility.
The snippet I posted above does the trick, but also styles the values of the task’s other tags.
Ah… I missread, maybe this then:
run[tag="data-due"][tagvalue] {
color: red;
