I’ve committed to working on more standard text input/replacements after rich text, but then I’ll likely make another poll to gauge what I’ll work on after that.
One thing I think would be awesome as my collection of docs grows is a simple dashboard/UI for viewing your docs just to help organize and find them.
I’m not sure. Can you give an example from other apps of what you mean?
I do hope to eventually add a “workspace/library” option to Bike. Where you can open a folder and then see a folder hierarchy in sidebar that you can navigate and open files from. That feature is still quite a ways off though. I have a lot more work on basic editor for now.
Ah … a workspace/library would be great!
Something like this. Just a simple version though to view your docs sorted by recently used if you feel fancy. Just a super simple viewer.
I may be willing to do the UI design if it helps.
