Him Jesse,
I tried to use Today.script but
"Error “Bike found an error: I can’t transform "2026/00/00" into integer type.” number -1700 from “2026/00/00” to integer
what can I do?
Him Jesse,
what can I do?
@amelchi Can you tell me which version of Bike you are using? And also are you using the copy of the “Today” shortcut from above in this thread?
Also, in general this today behavior, and a whole bunch more is no build into the Bike 2.0 preview. I would recommend switching to Bike 2.0 and using that built in functionality as a best solution.
(I’m not certainly if the built in function will integrate well with your existing date structure or not, but it should be an easy fix if it doesn’t. Give it a try and I’ll be happy to help fix anything up if needed)
I am on Bike 2 (293); normally I prefer scripts over shortcuts…
Today shortcut works, thanks
Any way to have it append instead of prepend?
