I’ve just posted Bike 176 that I think adds the missing piece for what you are trying to do. Now the edit rows action also takes markdown input.
But when the Bike action is taking Markdown as input and is passing it to Bike as rich text, do you use a different method?
Yes. In this case the Shortcuts machinery is just delivering me a plain markdown string, and it’s my application code that converts it from markdown to rich text. It seems to be the boundary between actions that (that must flow through shortcuts application) can’t handle rich text…
Although even that isn’t completely true. For example if I get rich text from a Bike row then it does also display as rich text in Shortcuts output. All very confusing, but I think there are definitely some bugs there that are not mine.
Sadly I have everything in the Setapp version, so now it gets confused, heh… I have to migrate all the actions, and can’t just plug in the one(!) I need at the end.
Guess that’s a good reason to buy a license directly. (But my original plan was to do that, but still use the Setapp version, so some money trickled your direction…)
What happens if you load in this? That one has actions from Setapp and Preview mixed… (I’m trying to make it shareable, so it’s interesting to know.)
I think I need the tutorial. You were going to write up a post? Maybe write it up, but before posting let me try to go through and see if it works for me. I’m sure it can be made to work if it’s working on your computer. But I’m not really understanding the results of what’s happening at this point.
I’ll make a screen recording for a tutorial tomorrow, and you can then see if it the shortcut package works on your end? (When you get the time - won’t expect you to work during the weekend!)
