Yeah that probably makes sense. I hesitate because I’m already using that shortcut for Copy Link, but I expect that’s used by very few people at this point. Code likely a few more.
What would highlight look like? “Mark” could confuse some folks.
Highlight will do some form of draw a yellow background for default styling. I think I’ll continue to use “Highlight”. And @complexpoint has convinced me … I’ll rename to use Bold and Italic for the other menu items. Not care so much about trying to map to element names.
I personally use that kind of semantics quite a lot, and it’s a standard part of the MD repertoire, for what that’s worth, but maybe that can be done by a row style and custom attribute ?
it’s the most remarkable tool that we’ve ever come up with, and it’s the equivalent of a bicycle for our minds – Steve Jobs
I didn’t remember q. Is that supported by Markdown or any other macOS/HTML tools?
I do want to add row level blockquote, but that will require stylesheets first.
I think this will be built in and also encoded in Bike file format as an element. Right now the file format only has one block level element p. I think (not sure) that block level elements such as heading, blockquote, etc will be represented by using a different element tag. And then in stylesheet tag can be referenced. That’s my current idea anyway.
Thanks for links. My hesitation with ⌘⇧J is that it seems like such a useful/easy shortcut in general, I feel like it would be wasted on “code” which is a lowly formatting feature.
I am now trying out ⌘⇧` for now, where the character is the impossible for me to figure out how to write markdown syntax for “code”. It’s not super easy to type the shortcut, but it’s easy to remember since association with markdown.
I use Keyboard Maestro mostly for text expansion for similar reasons. It’s not quite as great as a dedicated expansion utility, but it does so many other things it’s still the solution I would recommend.
Could you please explain how to set up underline in “styles”? I found this discussion specifically to figure out why I couldn’t underline. I’m trying Bike as a companion to Scrivener in the writing process and use underlining as a way to emphasize ideas for myself (bold and italics have other uses in my thinking+writing process, so I don’t want to substitute). So allow me to be the first person (if no one else has written in since July) to ask for it!
The third form of emphasis used by Bike is Highlight (⇧⌘H), which uses the standard HTML <mark> tag.
You could paste unindented text, preserving highlights and other formats, into Scrivener using a script like this (originally intended for Apple Mail):
If you are very strongly attached to <u>, which sees less use these days, we might also be able to write you a script which pasted Bike highlights as RTF underlining.
