I’m just heading off, back Sunday! This release should work a bit better when you’ve got multiple windows/tabs open on the same document.
- Document “Edited” status shows for all Document windows/tabs, not just first
- Added scripting API to get all OutlineEditors associated with a given outline
- Fixed scripting API to pass in the “front” editor, instead of always the first one created
- Fixed document panels (save, print, etc) to show over active window, instead of just first document window
Issue Tracker
