Looking at code, I think it’s not working because of a private API change. Unfortunately to make tab views have custom titles (separate from NSWindow title) I needed to use private API. Somehow that API has changed, and so my custom titles don’t seem to be working anymore. Sorry I don’t see a quick solution at the moment.
Not sure, but I think you guys might be talking about slightly different things.
If you have different documents open in tabs of the same window, then you should see “FileName • Focused Project” as @fssbob describes.
The behavior that’s missing is when you have a single document open, with multiple tabs (different views into that document). In that case it used to be that each tab displayed only the focused project name. Now it just shows the file name.
The underlying difficulty is that it’s not possible (that I know of anyway) to display a different name in a tab from the name that’s displayed in the window titlebar, when that tab is selected.
I could add an option to allow you to always show the focused project along with the filename in all windows if that would be of value. It’s a bit of redundant information, and why I hacked around the problem. But I guess now that that hack isn’t working you are seeing the redundant information (the same filename listed in all tabs) anyway.
Let me know if you think that change would help.
For WriteRoom 4 (and future TaskPaper 4) I’ve written my own tab view implementation so I can display whatever I please without any hacks!
Yes, please add the project title to all tabs. I use a single TaskPaper document and open different views to the document in different tabs. Without the project name, this approach is useless, as I have no way of differentiating between the views. I also have a couple of related requests:
Currently it displays the .taskpaper extension in the tab, which wastes of a lot of space and is useless information. Is there any way to suppress the display of the extension?
When a saved search filter is active, display the name of the search instead of a project name. Same thing for tag filters.
I’ll also look again in to getting this in to next release. When I initially released TaskPaper 3 is had this behavior. But ti achieve it required private API hacking… and then due to some internal changes in Apple’s frameworks those hacks broke. I’ll see if there’s a cleaner way to do this again.
In the long term (for version 4 of my apps) I’ve written my own tab view so that I have full control over those labels.
