Is it possible to search for specific row types? For example, I want to find all checked/unchecked tasks, quotes, etc.
I tried to type []
in the search field, but it doesn’t seem to be working.
I tried to type []
Have you seen the relevant examples here:
In particular, within outline paths, you can match on the following row type names:
body
heading
quote
code
note
unordered
ordered
task
hr
Matches any type
To expand on what @complexpoint says. Yes, but using the mechanisms in the above linked guide, not using Bike’s standard search field. I’m working on Bike 2.0 (now, and for the past few months). A bit feature of 2.0 will be the ability to filter your editable outline by outline path searches.
Thanks for the link! I’ll check it.
