I made a simple script that many plain text editors have for toggling comments.
(Of course it has to be ⌘/, which takes up the Show Status Bar shortcut)
set ls to selection rows
repeat with each in ls
if type of each is body then
set type of each to note
else if type of each is note then
set type of each to body
end if
end repeat
end tell
(Its behaviour differs only when rows of different types have been selected – toggles all selected rows together, basing the toggle direction on the type of the first selected row).
i.e. equivalent, in AppleScript terms, to something like:
Expand disclosure triangle to view AppleScript source
if it exists then
set selectedRows to a reference to (rows where selected is true)
if 0 < (count of selectedRows) then
if body is type of (item 1 of selectedRows) then
set toggleType to note
else
set toggleType to body
end if
set type of selectedRows to toggleType
toggleType as text
else
"Nothing selected in '" & name & "'."
end if
else
"No document open in Bike."
end if
end tell
