I had been using this nifty pair of scripts that format from TaskPaper to FoldingText “syntax” (and back). I haven’t had a call to use either for a while, but when I did today, the clipboard contained only the following:
TypeError: editor.selectedRange is not a function. (In 'editor.selectedRange()', 'editor.selectedRange' is undefined)
evaluateScript@file:///Applications/TaskPaper.app/Contents/Resources/bircheditor.js:40:26288
Use the Help > SDKRunner to debug
I’m at a loss for where to try to fix this. I don’t think it’s something with the AppleScript since was working fine for quite a while. Any suggestions would be greatly appreciated.
The AppleScript code is here:
property pTitle : "Copy from TaskPaper in FOLDINGTEXT format "
property pVer : "0.1"
property pAuthor : "Rob Trew @complexpoint on Twitter"
property pRepo : "https://github.com/RobTrew/txtquery-tools"
property pLicense : "MIT"
property pstrJS : "
function(editor, options) {
// HOW MANY PRECEDING TABS OR HASHES FOR THIS LINE IN FT ?
function FTPrefix(oNode) {
var oParent=oNode.parent, lngLevel=1, lngProjLevel=1, blnFound=false,
strType=oNode.type(), blnProj = (strType == 'project'), strPrefix;
blnFound = blnProj;
while (oParent) {
lngLevel++;
if (blnFound) lngProjLevel ++;
else blnFound = (oParent.type() == 'project');
oParent = oParent.parent;
if (blnProj) strPrefix = '\\n' + Array(lngLevel).join('#') + ' ';
else strPrefix = Array(lngLevel-lngProjLevel).join('\\t');
return strPrefix;
// GET THE SELECTED LINES
var lstNodes = editor.selectedRange().nodesInRange(),
lstLines=[], varNode, strLine, rgxEndColon = /^(.*):(.*?)$/;
// AND GIVE AN FT PREFIX (HASHES OR TABS) TO EACH ONE
lstNodes.forEach(function (oNode) {
strLine = oNode.line().trim();
// REMOVING THE COLON FROM PROJECTS (BUT LEAVING TRAILLING TAGS)
if (oNode.type() == 'project')
strLine=strLine.replace(rgxEndColon, '$1$2');
lstLines.push([FTPrefix(oNode),strLine].join(''));
return lstLines.join('\\n');
on run
set varResult to missing value
tell application "TaskPaper"
set lstDocs to documents
if lstDocs ≠ {} then
tell item 1 of lstDocs to set varResult to (evaluate script pstrJS)
set the clipboard to varResult
end if
end tell
return varResult
end run
