Possible bug: encoding of HTML pasted into Bike
I think there is a bug in the handling of HTML (public.html) pasted into Bike. It seems that Bike is assuming that HTML is iso-8859-1 encoded when it doesn’t know what the encoding actually is.
When I put
<b>français</b>
on the clipboard (various ways, including writing a pyobjc program to write a public.html string to the clipboard) and paste it to Bike, I get
français
which matches
print('français'.encode('utf-8').decode('iso-8859-1'))
français
Interestingly, if I put
<meta charset="utf-8"><b>français</b>
as public.html on my clipboard, the pasting into Bike works properly.
(I’m using the latest Bike version 1.18.2 Preview (176). I Love Bike!)
Seen here, too, I think.
The JavaScript for Automation code below seems to retrieve <p>Français</p> intact as UTF-8 from the public.html pasteBoard after setting it, but if we then paste it into Bike, we see:
Français
    "use strict";
    ObjC.import("AppKit");
    const main = () =>
        either(x => x)(x => x)(
                setClipOfTextType("public.html")(
                    "<p>Français</p>"
                clipOfTypeLR("public.html")
    // Left :: a -> Either a b
    const Left = x => ({
        type: "Either",
        Left: x
    // Right :: b -> Either a b
    const Right = x => ({
        type: "Either",
        Right: x
    const either = fl =>
        fr => e => "Left" in e
            ? fl(e.Left)
            : fr(e.Right);
    // clipOfTypeLR :: String -> Either String String
    const clipOfTypeLR = utiOrBundleID => {
            clip = ObjC.deepUnwrap(
                $.NSString.alloc.initWithDataEncoding(
                    $.NSPasteboard.generalPasteboard
                    .dataForType(utiOrBundleID),
                    $.NSUTF8StringEncoding
        return 0 < clip.length
            ? Right(clip)
            : Left(
                "No clipboard content found " + (
                    `for type '${utiOrBundleID}'`
        txt => {
                pb.clearContents,
                pb.setStringForType(
                    $(txt),
                    utiOrBundleID
                txt
I’m not sure if this is the defined behaviour, i.e. what default encoding is assumed in the absence of an explicit charset="utf-8" in the pasteBoard HTML.
(macOS does have a murky MacRoman encoding inheritance from its pre-history, which still occasionally shows through :slight_smile:
for example, the same thing happens if you paste your HTML pasteboard into TextEdit …
If we put <p><i>Français</i></p> into the public.html pasteboard, and paste to TextEdit, the italics get through, but the encoding is not UTF-8)
Thanks for confirming what I’m seeing!
I’m able to paste my HTML into at least MS Word and Obsidian without problems – they seem to default to UTF-8 when the encoding is uncertain. Or doesn’t the macOS clipboard actually understand the encoding of strings and bike is assuming iso-8859-1 when the HTML doesn’t explicitly say UTF-8?
Confirmed here too – after:
    "use strict";
    const main = () =>
                    "<p><i>Français</i></p>"
        type: "Either",
        Left: x
        type: "Either",
        Right: x
            ? fl(e.Left)
            : fr(e.Right);
            ? Right(clip)
            : Left(
        txt => {
                pb.clearContents,
                    $(txt),
                    utiOrBundleID
                txt
pasting to MS Word (unlike pasting to TextEdit) seems to involve a default to UTF-8
Screenshot 2024-04-13 at 7.20.38 PM
As a footnote, we can reproduce this behaviour by replacing $.NSUTF8StringEncoding with $.NSASCIIStringEncoding in the JXA expression:
ObjC.deepUnwrap(
        .dataForType("public.html"),
and not sure if it’s relevant, but I notice that if we supply a null or void value for the encoding argument in a function like NSString’s initWithData:encoding: then a message tells us:
Incorrect NSStringEncoding value 0x0000 detected. Assuming NSASCIIStringEncoding. Will stop this compatibility mapping behavior in the near future.
(Perhaps Apple would do better, in a macOS Unix context, to assume NSUTF8StringEncoding)
@jessegrosjean I wanted to flag this thread for your attention – I think there’s a bug in how Bike handles the pasting of HTML with ambiguous character encoding.
Ah, thanks! I saw this while I was away… and then got onto other things and forgot. Will look into this today.
I’ve just posted a new preview release which I think fixes this problem:
:+1: working well here now.
(Bike 1.18.2 (177) – Sonoma 14.4.1)
Bike 1.18.2 (177) Preview seems to have fixed the problem for me too. Thanks @jessegrosjean !
