Feature Request: file:// link for home ~/…
I just discovered, that I can use clickable file paths like /Users/me/Library to open a file or folder. Unfortunately ~/Library does not work.
Nils
I’m not sure about supporting ~ paths, can you use relative paths to solve problem instead?
More info here:
https://guide.taskpaper.com/reference/links/
relative paths are even better. Not sure why I haven’t tried this.
This seems to be an overall experience with TaskPaper: most of the problems I run into are already solved :wink:
Nils
