Using the checkbox in .todo mode uses sometimes the wrong line
If I use the checkbox in .todo mode the line with the cursor focus will be checked and not the line with the clicked checkbox.
Regards, Volker
Are you using the latest version? This doesn’t seem to happen for me in my dev version. Anyone else seeing this?
@Volker I believe that clicking the checkbox simply calls the ‘done’ command. If you have a plugin that’s overriding that command, it may be the source of the problem.
@jamie that is possible. I will check the plugin. Thank you for the tipp.
