Theme demonstrating multiple header styles
Continuing the discussion from Visual cues for headers:
Yes, after installing this theme FoldingText h1, h2, and h3 headers will have distinct styling.
.CodeMirror {
	.cm-heading {
		font-weight: normal;
	.cm-heading[cm-level="1"] {
		font-style: normal;
		font-weight: bold;
		// You can also change the size by uncommenting
		// the following two lines.
		//font-size: @fontSize * 1.5;
		//line-height: @lineHeight * 1.5;
	.cm-heading[cm-level="2"] {
		font-style: italic;
FoldingText Extensions Wiki
Hi Jesse,
This is useful! Can I ask whether it’s possible to style a particular heading? For example, ## IMPORTANT always turns red?
Thanks in advance,
Mark
Sorry I don’t think so. FoldingText styling is all done directly through DOM/CSS … and when searching I just found this:
Which says you can’t use CSS to style based on element text content. I think best approach here would be to add an @important tag and styled based on that.
Thanks, Jesse. Appreciate your response, as always.
