Taskpaper and Resume
I’m a taskpaper user and I have multiple Taskpaper documents. I often have several open at once, and I like launch the app with a clean slate so I quit the application with option-command-q to prevent OSX from reopening the tp documents that were last open. In 10.10 I can’t seem to get the behavior to work properly. TP still opens the whatever windows I had open when I quit the app. Can someone test this behavior? Am I missing something? I am running version 2.3.2.
Thanks,
Michael
This feature is implemented within TaskPaper itself (before OS X supported it) and so OS X preferences can’t change it. Eventually I’ll be releasing a major update to TaskPaper that I expect will use the OS X standard behavior, but that’s still some way off.
Thanks for the response, Jesse.
